Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
Bu yanıt yardımcı oldu mu?
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 15,487
1 Yorum
Make sure bearing is assembled properly just behind steering wheel
p_buchwald tarafından
