ipad wont charge when connected
Hello,
I have an ipad air 1 and recently it wont charge at all, I connect it to the computer and it is detected but just wont charge, I connect it to the wall outlet and it wont charge and the charger is not detected (apple branded charger). However, the only way I can charge the ipad is by connecting it to the wall outlet and turning the ipad off and while it is off and connected to the wall charger it charges up. Any idea what is causing this issue. thank you greatly.
Jorge
Bu iyi bir soru mu?
I suddenly started having this same problem. I can move the lightning plug around a slight amount and the screen will show charging for a few seconds then displays "not charging". I then turn it off and leave it plugged in and it will charge but not while it is "on". I first thought it was a faulty cable or cube but by swapping them around I isolated it to the iPad connector. I sprayed contact cleaner in the port but still no good. I am afraid it is an internal problem. Hope for good news from someone out there!
Jim Miller tarafından Paylaş
