My laptop produces a whisle sound
my laptop does not start and produces a whistle
Bu iyi bir soru mu?
Bu iyi bir soru mu?
hoby25588 , you could try a resest, disconnect the charger,remove battery,press down the power button for 30 seconds, install battery and charger, power on system. The whistle you here may be a faulty fan,take laptop apart and give a good cleaning especially the fan and try, a can of compressed air should help blow dust, etc. out. If fan is still not functioning properly replace it, as it can cause issues. If it is not a whistle and computer is beeping, these are error codes depending on the amount of beeps. Use the link below for explanation of beep codes and possible fixes. Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 74
