Ana içeriğe geç
How to upgrade the M.2 SSD
Dear ifixit team,
I have an HP Spectre X2 Detacheable 12 inch tablet. However, the unit comes with a 128GB M.2 2280 ssd. Does anybody know on how to open the unit in order to replace this ssd with a larger capacity? Thank you so much for your answers. Regards Surfix007
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here is the "end of life" recycling guide that shows some basics on how to take the spectre x2 apart. Would be a good place to start on a project like replacing the SSD.
http://h22235.www2.hp.com/hpinfo/globalc...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I have HP Spectre X2 12-a009nr. Theres no 4 screws like in the link that you provided :(
tarafından
I think you need to follow this guide: http://h22235.www2.hp.com/hpinfo/globalc... . If so then I won't touch it as it is glued together.
If, however, you have found a solution please let me know as I would also be interested to know
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
you can open the machine without removing the screen from the bezel.. use a spudger between the black plastic bezel and metal frame. It will pop off easily, and reinstall with no glue. I take mine apart for fun. the drive is a standard m.2 sata ssd
Puan 0
1 Yorum:
Start in the upper right corner near the power button.
tarafından
Yorum Ekle
Yanıtını ekle
Rainer Michelis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 2,325
