Ana içeriğe geç
23 Ağustos 2007'de tanıtılan Nikon D300, Nikon Corporation tarafından üretilen 12,3 megapiksel yarı profesyonel DX format dijital tek lensli yansıtmalı (DSLR) fotoğraf makinesidir.
Problems with focus and shutter speed
My camera is having trouble focusing on the subject and so it won't take the pic for a while and then when it finally does the shutter sound is very slow no matter what setting I have the camera on.
I have stopped using it because this is so frustrating.
Pics are not focused properly and badly lit.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Under what conditions is this happening, in what lighting conditions etc..
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Your shutter is probably used up to its designed lifecycle. I have the same problem of shutter being slower than what the setting shows, which definitely leads to over exposure. I have to switch to continuous shooting mode (either H or L) to try more frames to get it back to the correct speed. Somehow the problem pops up again and gets worse through time. I guess I've clicked it for over 100,000 times over the last 7 years since I bought it. Aging was what my photographer friend suspected. Will check out.
I'm using a 17-55mm f2.8 lens as standard fitting , perfect for DX format and so far extremely rarely does focus error occur.
Puan 1
Yorum Ekle
It seems to be costant with the shutter. I can have it on 500 and it sounds like under 30. The focus seems to happen mostly indoors when I want a flash.
Puan 0
1 Yorum:
are you using live view when taking pictures or are you using the viewfinder, what mode are you using your camera in (auto/p/m/a/s)?
In auto mode the camera will try and guess what type of picture you want and use settings accordingly.
AF can struggle under low light conditions meaning it can take longer to get a lock, even with the AF assist light on, that would be consistent with what you are describing.
you could try putting the camera in aperture priority mode , and open it up as far as your lens will let you to let as much light in as possible, turn the ISO as high as it will go, switch the focus switch on your lens to (M) and use the viewfinder to focus on you subject. in the viewfinder windows it will show your shutter speed, and take a picture to see if you get the same results. bare in mind that the picture will be grainy down to the ISO noise.
this doesn't sound like a hardware fault but rather the camera settings, if all fails try doing a factory reset on your camera
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
camchap20 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 2,975
