Ana içeriğe geç
The Moto G4 Plus is an improvement on Motorola's Moto G4. The Moto G4 Plus offers a fingerprint sensor, increased memory capacity, and an improved rear camera. Model number XT1642 and XT1644.
73 Soru Tümünü görüntüle
moto g4 plus Micro USB Replacement
Can you put up a video on how to replace the micro usb port on the moto g4 plus?
Mine had the plastic literally melt after connecting in to an apparently faulty car charger.
Much Thanks and keep up the great videos!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
4 Yorum
Your phone didn't warn you what was happening?
tarafından
Hi, did you solved this problem? I need to replace my charging port too.
tarafından
Nope, ended up sending it in on warranty and getting a new phone.
tarafından
Hi
I purchased a rebuilt Moto G 1st generation smartphone but the charger port was broken after I paid for it , and before I received it.
Can you provide an instruction manual or video? I have seen one but the soldering alone I know is more than I can do myself. Can you help?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
william_oliveira87, John Linden, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a USB charge port attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=8jqw-KwC...
https://www.youtube.com/watch?v=Bl_6g4GV...
http://www.ebay.com/itm/2X-Dock-Connecto...
Bu yanıt yardımcı oldu mu?
Puan 7
Yorum Ekle
Yanıtını ekle
John Linden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 10,535
