Ana içeriğe geç
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Bu iyi bir soru mu?
Puan 2
6 Yorum
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
tarafından
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
tarafından
cant get it to work either way.what to do ?
tarafından
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
tarafından
I've got it working, see my answer below.
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
tarafından
Yorum Ekle
En Yararlı Yanıt
On your RCA tablet go to settings, click on display and then configure HDMI settings.
Puan 1
1 Yorum:
What do you do after or even how do you configure HDMI settings
tarafından
Yorum Ekle
Yanıtını ekle
boogityboo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 13,203
