Ana içeriğe geç
Tivax MiTraveler 10Q-8 tablet modeli. Android 4.1 Jelly Bean işletim sistemi.
Reset to factory settings
When I reset my MiTravler back to factory settings it comes up all the time to input some codes ( numbers) in order to proceed, how to bypass and reset manually
Bu iyi bir soru mu?
Puan 0
1 Yorum
My mitraveler tablet is froze up need to reset it how do I do that
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
leroysimpkins, from pg.17 of MiTravler manual.
Restore default setting, if you want to reset the factory setting and erase all materials, please press,
Settings → Backup & Reset → Factory data reset.
  • Warning: Factory data reset setting will delete your Google account information, data and configuration of system and applications from downloading.** Please use this function carefully.
Link to manual below. Good luck.
http://www.tivax.com/media/downloadable/...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
what about the up/down key while pushing the on button
tarafından Paylaş
leroysimpkins, Yes you can try that it works on some devices, also note below,
From page #3 in your manual. Important Notice
-If the device is freezing or stuck, press the reset button(a small hole) or
long press power button for 7 seconds.
-When the performance is slow after using some applications, it is
recommended to close running application in setting menu.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
leroysimpkins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 2,556
