Ana içeriğe geç
Acer Aspire V3-771G laptop. This is part of the 17.3" screen lineup that Acer offers.
14 Soru Tümünü görüntüle
Why is my screen going crazy with green/purple lines and flickering?
Ok, so I've had this laptop for about 3 years now. It's been working perfectly fine for the most, until my screen decided to start going crazy with colors and flickering. The screen every now and then starts flickering or it start displaying intense green or purple everywhere, but only in certain positions (angle between screen and laptop body). Also I've found a temporary fix, which is to apply pressure at the bottom part of the screen (I have a piece of cloth that I squeezed in between the laptop screen and the body, so that it applies pressure to the bottom part of the lcd)
So I've opened up the laptop to check if there wasn't anything loose or a cable that was badly connected and found nothing.
I've searched online quite a bit a found nothing either; I can't even determine what is causing this (GPU, LCD screen, cables...) so i can't even start thinking what i need to replace, or if it's even worth trying to repair.
If anyone could help would be greatly appreciated.
Bu iyi bir soru mu?
Puan 2
2 Yorum
Same thing wit me except its on an acer monitor connected to my ps4
tarafından
Hi @Roger Rivera,
What is the model number of the Acer monitor?
Can you connect a different monitor to check if the problem is with the monitor or the PS4? Even a TV can be used as a monitor as long as it has HDMI inputs and you have the appropriate HDMI cable to connect the two together.
Have you tried a different cable between the monitor and the PS4?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
gus bern possibility of bad logic drivers for the LCD panel is the first thing I would suggest. To determine if it is your LCD, connect an external monitor to your computer. If that shows appropriately then you know the GPU is working and the issue is with your LCD.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks, i tested it with a monitor and it worked fine.. guess its the lcd screen then.
tarafından
Yorum Ekle
Yanıtını ekle
gus bern sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 105
Her zaman: 18,953
