Can I add an SSD drive in addition to existing HD?
Hello! New to the forum, was curious if I can Add a SSD in addition to my current stock HD? Thanks in advance! My current laptop is an Asus Q552UB
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Howdy!
I'm sorry but answer is NO... :( You cannot add SSD in addition to your stock HDD because ASUS Q552UB has only one internal Serial ATA interface. In case that you will need SSD instead of your stock HDD, you have to replace it by appropriate 2,5" Serial ATA SSD drive.
If you need to connect additional storage, it must be connected via external USB 3.0 port (transfer rate 5Gbps) so I suggest to use some small factor USB 3.0 flash drive like Samsung 128GB USB 3.0 Flash Drive Duo (MUF-128CB/AM) - see on Amazon: http://a.co/1ZmmJ2a
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 427
