Screw hole pry damage
Hello. I have iPhone 6 not turning on after screen replacement and iTunes doesen't recognize it. Not heating at all. There are pry damage on the screw hole (middle one) - whole BS2503 is off the board and you can see the copper there. Also it seems that the backlight filter FL2024 is kind slightly burnt. Also there seems to be long screw damage on the two bottom screw (there are copper) but before I take those off and check under those screw holes.. is there anything to do? Please see the pictures.
Is that burnt filter causes that the iPhone is dead or is there something messed up under the middle screw hole? Is that necessary that it is attached to the board?
Any help would be appreciated.
Bu iyi bir soru mu?
