Ana içeriğe geç
Big Wheel, genellikle plastikten yapılmış, yere çok yakın sürüş sağlayan ve alışılagelmişin dışında büyük bir ön tekerleğe sahip bir üç tekerlekli bisiklet türüdür.
Steering column is stiff
I recently put together a kids big wheel and the steering column is very stiff and will hardly turn. Obviously this isn't something that is adjustable given the set up, but I need simple solution so my three year can steer it. Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try adjusting the height of the handlebars by loosing the screw in step #5 of this PDF and lifting slightly till it turns freely then tighten it back down:
originalbigwheelparts.com/images/bw_assy_instructions_pictoral.pdf
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Kristina Johnson, This may also help, take the column back apart and apply a little/ thin coating of Vaseline on column and reassemble. Good luck.
tarafından
Neither of the above helped a bit. Cannot be steered by a child.
tarafından
Item is a piece of junk.
tarafından
Agree, the Big Wheel has been unused for over a year. Every few months my kids and their friends get on it and just as quickly get off. I would greatly appreciate someone sharing a fix if there is one out there
tarafından
Yorum Ekle
To any parents who bought this for their kids for Christmas and are running into this problem - the solution is candle wax!
Simply apply a thin layer of wax to any surface that rubs in the steering assembly (underside of the handlebars, front fork spindle, inside the hole the spindle goes through, etc.).
I was a little skeptical given the apparently unsuccessful petroleum jelly suggestion, but gave it a shot anyway, as I've used candle wax to lubricate wood in the past.
Not sure how long the effects will last, but it works great so far!
Puan 0
Yorum Ekle
Yanıtını ekle
Kristina Johnson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 2,268
