Replacement power supply ps4
Hi i bought a brand new PS4 slim and it got a roach infestation which voided my warranty I need to get a new power supply where can i order one.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
UPDATE: These are available on Ebay and Amazon now.
There is nowhere currently that has those in stock. You might keep checking Ebay as they may have them periodically but there is nowhere that stocks them consistently.
Don't purchase them from the links that other have posted as they are not for the PS4 Slim.
Hope this helps.
Bu yanıt yardımcı oldu mu?
@tronicsfix ,TronicsFix, can you assist instead of voting down would be appreciated, the link I posted says for Sony PlayStation 4 PS4 500GB Slim Console .
These parts are not available. It doesn't matter what the link says...when you click on it it takes you to a part that is not the correct part. This is very confusing to someone and may cause them to purchase a part that is not correct. I'm more than happy to undo my downvote once the answer has been edited to give correct, useful info as well as the down vote is removed from my answer.
@jacksonfamily , devin allen , Link to power supply for the ps4 slim tear down which may aid in replacement of the PSU. You will have to do a google search for your power supply as it seems, I have had no luck as of yet, (always ensure it is the correct part for your device before ordering).
Good luck.
The link for the power supply you posted is NOT for the PS4 Slim.
TronicsFix, I do not intentionally give incorrect info., can you assist instead of voting down would be appreciated, the link I posted says for Sony PlayStation 4 PS4 500GB Slim Console , do you have a part #. Thanks in advanced, I await your reply.
@tronicsfix ,edit was made, saying (always ensure it is the correct part for your device before ordering), can you share a part # that client should look for. Thanks in advance.
Look, the link you give goes directly to the wrong part. There is no point in saying " Links to replacement power supply for the ps4 slim" when it's the wrong part. It doesn't matter if you say "always ensure it is the correct part for your device before ordering"...you're linking them to the wrong part. Please remove the link. You must be an aliexpress affiliate or something.
Wha th gotta check for is it ur ps4 is a CUH-2015a oor CUH-2115b those are the two types of power supplies for ps4 and u can find them on Amazon or eBay for 40-60 bucks what u gotta decide is what brand u want
you can swap the connectors on the psus to make them the same one is flipped the opposite way but if you swap them from the broken 15 to the 16 bingo it works
What happen to your game did the power just go out randomly and didn't come back on
Son 24 Saat: 1
Son 7 gün: 23
Son 30 gün: 32
Her zaman: 10,288
8 Yorum
PS4 Slim power supply part number
N15-160P1A
Regardless, can't find it anywhere:(
Michael Thompkins tarafından
Michael Thompkins, thanks for posting the part #, that may aid the client in finding one eventually,why would you vote down my post, I am at least posting a tear down link for the slim.
L Pfaff tarafından
i have same problem and cant return to walmart is past the 15 day return exchange it sucks
Doris Leesman tarafından
You can purchase the power supply on Ebay now if that's what you need. My business also repairs these so I can help you out if needed.
TronicsFix tarafından
will a n15- 160p1a work in place of a n16=160 p1a
Dustin Kelley tarafından
3 tane daha yorum göster
