Ana içeriğe geç
The Samsung NX Mini is a mirrorless digital camera released in March 2014.
9 Soru Tümünü görüntüle
My camera wont focus
My camera is having trouble with auto focus. On auto I can hear it trying but the picture just get more blurred. On the smart settings I can get it to focus but it requires zooming in more than I would like.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
see if motor focus len is work free and correctly, if it have a slack in gear, possibly have to change th lens.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Another thing you have to check is the linear resistor - ie the sensor that detects the focal length. If the ribbon is loose from its connector, it may not giving this information. So it is stuck at a specific focal length. You can check if this is it, if the you can see picture on the LCD before you rotate the lens to the normal shooting position. I mean, when the lens is in its OFF position.
In order to access the aformentioned connector you need to:
1) Remove the back cover
2) carefully remove the ribbon that is attached to the outer contacts by lifting up the lock mechanism on the back side of the connector (the opposite side of where the ribbon is inserted).
3) There are 2 connectors remaining, the smaller one is the one to check.
Puan 0
1 Yorum:
Hi! So if I can see an image even if the lens is in the "off" position, that would mean I have that "locked at a specific focal length" problem?
tarafından
Yorum Ekle
Yanıtını ekle
Shatia Thompson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,128
