Bezel ring repair or replacement
My bezel ring fell off my watch. Can you fix it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I just found this a few days ago. I have ordered the parts. :)
https://www.youtube.com/watch?v=puASQxWC...
Much luck!
Bu yanıt yardımcı oldu mu?
where did you order from?
You can find them on eBay and on Amazon, the Amazon ones are for the rolex submarines, but I would think that they can work, the link is https://m.aliexpress.com/amp/item/327710... . Keep in mind that you will have to find out the size of the watch face or bezel so that the insert will fit perfectly and so that it may not even need the use of glue. So I would suggest going to a jewelry store and seeing if they can inform you on the correct size insert to buy. And you can get it from multiple different sites, not Just the one I provided.
You can Glue it on with gorilla glue or sticky silicon glue. The inner part of the bezel is called a bezel insert, I have looked all over the net for ways to repair it and have only found one video as listed by the poster above. But if you entirely lost your bezel insert on the street or anywhere and do not have one in possession, you can just get a bezel insert from a old watch or order one . After getting a new insert, you can just glue it on. Just be sure to find the right size, for example: if the bezel size is 44mm, buy a 44mm bezel insert. This will work.
My bezel fell off my Gs2 watch how easy to get another and repair?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 24,421
https://rounded.com/gear-s3-frontier/
Fernand tarafından
My bezel ring is very difficult to turn either direction it's very sticky , how can I take it off and clean it and put it back on
kydzdt tarafından
