Ana içeriğe geç
2006 yılında piyasaya sürülen 6,0 Megapiksel kamera ve 4x optik zoom lensine sahip Canon PowerShot A serisi kompakt fotoğraf makinesi.
DIY "hot" spring fix
I have an A530 that was included in the recall for the "hot" spring but I didn't know about it and Canon won't fix it now. Does anyone have a diagram of what the problem was and the DIY fix that I've seen talked about, but never described?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
John Darago this was recalled because a little hinge spring in the door of the battery compartment can stick out and short the batteries. Result is poor battery life, and a hot battery door.
Resim
You could try to shorten the spring, use a small Dremel like tool with a cut of wheel or simply place a piece of electrical tape over it.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I don't know if all A530s are like this, but I took the battery contact plate off by removing the two screws. The back side of the plate had a slot that the arm of the spring was supposed to fit into. I guess when it was assembled, the spring arm wasn't placed properly. If you decide to examine this, be careful. There is a little spring behind the plate that could "spring" away.
tarafından
Those springs in the battery doors are the major reason why I do not like to work on cameras. A royal PITA to deal with those :-)
tarafından
Yorum Ekle
Yanıtını ekle
John Darago sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 674
