Ana içeriğe geç
2006 veya 2007 yılına ait ekmek yapma makinesi
How to access timing belts
How to remove the covert to the timing belts on a BBA 2865 breadmaker machine
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Resim
Resim
Resim
Resim
Resim
Resim
Resim
Resim
Resim
Update (03.12.2022)
It cost me a lot of nerves to get the white plastic clips off. They are also a pain to clip back on later.
So finally, here the top is off, ready for the white plug to be unplugged:
Resim
Resim
The earth cable still has to come off:
Resim
Now take care of the on/off switch:
Resim
Resim
The switch cables can stay plugged in. Mine were so hard in, I feared to break them off. Just be careful.
Resim
Resim
Important for later assembly: the three spacers.
Resim
Now the way is clear to replace the timing belts.
Resim
Resim
Resim
Resim
Fixed. View from underwards:
Resim
Resim
Good luck! ;-)
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
Great tutorial, helped me a lot on a BBA 2594 machine.
Thank You!
tarafından
Thanks, it helped me too clatronic bba2865
tarafından
Regarding the power switch:
it is easy to disconnect - gently pull the contact pistons (at the ends of the wires going to the switch) out of the switch's contact terminals
tarafından
Yorum Ekle
Belt is at the bottom of the machine.
You need to:
  1. Remove the inner heat shield. It has 8 screws at the bottom and one on the side wall which is holding the heater. Remove it gently.
  2. Remove the top of the machine. Do not need to remove the lid. Just open it, remove the screws caps beneath the lead. There are 5 screws. Unhuk 7 plastic hooks just below the top.
  3. Remove base with the circuits, motor and heater. Unscrew all 6 screws. Remove GND (green and yellow) wire. Disconnect mains power connector from the circuit board. Gently pull out the base, watch for the on/off button.
  4. Remove the broken belt or wheel. Replace the belt or wheel.
  5. Put everything back in reverse order.
Puan 2
Yorum Ekle
Yanıtını ekle
Pat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 1,227
