Ana içeriğe geç
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Identify broken contact pad in charging port
Hi, I have this motherboard that has a broken contact pad where the charging port is soldered. I wanna try a jumper if its possible, but I am not sure where I should solder the jumpler wire to.
Look at the picture, from the botton up is the fourth contact pad that is missing.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
That pad looks like a ground to me. See the large blue trace? Thats usually a ground plane. Just bridge the pad that is left to the ground or put a jumper between 1 and 3 off what is left of trace. 4 and 5 look common as well. Use flux as solder wont stick as your working with it well.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Thanks for your reply, I just edited my question, I wrote third, but is actually the fourth one that is missing.
tarafından
Since the charging port you can buy the whole daughter board separately I personally would just stock up on these charging ports.
tarafından
My bad, didnt paid attention I had selected s4, the motherboard is from a SIII, the GT-I9300I. So, I don't have the option to replace just that part.
tarafından
I soldered the port back and didn't solder a jumper yet. It charges well, and connects to the computer well, too. I am still wondering what that pin is for, I guess it might be ground after all. However, in the picture Ben shared, it goes somewhere else.
tarafından
Yorum Ekle
En Yararlı Yanıt
Does this help?
http://www.mobilerdx.com/wp-content/uplo...
Puan 2
1 Yorum:
Thanks a lot Ben. I was looking for something like that.
tarafından
Yorum Ekle
Yanıtını ekle
marvmen21 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 447
