If your phone screen is black but the phone is still working, you can try the following steps to fix it at home:
1. Restart the Phone:
- Hold down the power button for about 10-15 seconds to force a restart.
2. Check for Loose Connections:
- Gently press around the edges of the screen to ensure there are no loose connections inside the phone.
3. Connect to an External Display:
- Use an HDMI adapter to connect your phone to a TV or monitor to see if the display works on an external screen.
4. Perform a Hard Reset:
- Consult your phone’s manual or search online for the specific hard reset method for your phone model. This typically involves holding a combination of buttons (e.g., power + volume down).
5. Check for Physical Damage:
- Inspect the screen for any visible cracks or damage. If the screen is physically damaged, it might need a replacement.
6. Battery Removal (if possible):
- If your phone has a removable battery, take it out, wait a few seconds, and then put it back in before restarting the phone.
If these steps don't work, you might need to replace the screen. Screen replacement kits are available online, but this requires some technical skill. If you're not comfortable doing this yourself, consider taking it to a professional repair service.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
28 Yorum
Is the screen cracked?
George A. tarafından
yes , from the top of the phone .
Jessie Calvin tarafından
While the glass may be cracked, check the corners carefully in the inner display of the screen. Usually there will be cracks in the corner if you can't find it.
Ben tarafından
mmm , I really didn't understand .
The cracks are in the right side from the phone on the top.
I can't find the inner display of the screen , I google it and I don't know how to find it . like .. Do I have to open the screen from inside or what ??
thnxx
and really i don't understand on mobiles and phones ..
23 tane daha yorum göster
