Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Fh code and hot water issue
Hot water will not shut off on Kenmore elite h3. Reading 8.03 across leads of switch. Cold water works fine. Drain pump makes noise and get a fh code. Checked pressure switch and hose, hose is good, switch clicks when you blow on hose.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@vongump if your switch does not turn the water off it may have failed in spite of the reading. Could be mechanical failure of the solenoid which could give you the FH reading as well. I'd start with replacing the water inlet solenoids.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Phil Haines sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 149
