Furby Keeps shutting down
I have a furby boom crystal and it keeps shutting down. I tried to hit the restart button it starts up then it shuts down. Do I have a defective furby?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the furby does not move and just constantly shuts down, then the the small 6V brushless DC motor went wrong. I had the same issue. You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good. You need a solder iron as well to replace electronic part from DC motor. If the furby does move, then there might me a sliced wire or a barely plugged in wire. I recommend you taking it apart, these newer furbys are harder to take apart, here’s a guide: https://learn.adafruit.com/furby-2012-te...
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 674
