Ana içeriğe geç
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Soru Tümünü görüntüle
Repair Magsafe 2 Charger?
Hi all,
I searched around for this, but most charging-related questions lead to troubleshooting the DC-IN, battery, etc and I couldn't find this issue specifically.
I'm an Apple Tech who doesn't have a background in electrical engineering - and made the mistake of daisy chaining a couple surge protectors together. They were like this for a number of months. This caused a few of my Magsafe chargers to go out. I'm curious whether the chargers can be repaired.
The symptoms:
  • The charger does not light up when connected to a machine (regardless of the machine).
  • The system battery icon shows that it's charging, but the status is "Battery is not charging." If I leave the cable connected overnight, the machine will usually charge up.
  • Hence, it seems the charger is providing power, but at a much reduced rate from what it should.
Is there a way to restore it to its former functionality?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Leave the chargers disconnected from the plugs for a couple of days, then try it. Sometimes magsafe chargers can disable themselves to stop overcharging a device.
Beyond this, I wouldn't bother repairing these. You have to break the casing in half, so it never looks great when you glue it back in place. The only reason I would consider repairing these is if the cable is frayed (but then again, I probably wouldn't bother), there are no schematics for the PCB inside the charging block so it can't be properly diagnosed. You can only repair this on a basis of "component looks bad, replace it".
If the 1st solution doesn't work, I would recommend just buying another from Apple.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Colin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,335
