Ana içeriğe geç
WD My passport 500gb not detecting showing unallocated 650gb
I'm a computer hardware professional. My WD My passport 500 gb is not detecting showing unallocated 650gb I Tried all kind formatting the drive. It shows unable to format. How to troubleshoot and what component will be the problem on hardware so that I can service myself?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First, open disk management. Find your disk in that list. Once you've found it, right click and hit delete volume for each partition on the disk. Once you've done this, the entire drive will become unallocated. Right click on the volume, and select new simple volume. Once this is done, it will ask you format it. Format it to NTFS. I hope I was of assistance to you.
Bu yanıt yardımcı oldu mu?
Puan 3
9 Yorum:
I did that and didn't work. When I create the partition it creates only 80gb in diskmanager and others unallocated unable to create or format the unallocated partition. And I used wd formating software, acronis disk director and partition magic tools software too it didn't work saying cannot format cycle redundary error
tarafından
Do not create any partitions. Make all partitions unallocated, the create new simple volume from that single partition. You cannot format unallocated partitions.
tarafından
tarafından
Why did you repeat it? I read it the first time.
tarafından
Did it work?
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Anzar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 3,433
