Ana içeriğe geç
Also called the Crosley Musician Entertainment Center.
20 Soru Tümünü görüntüle
Why does the record player play slowly
the record part of this machine plays the records slightly slower than they should be played. I am curious if there is a repair option for this, and where to look? Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
I just saw this post! This was my issue as well. Thank you!!!!
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had this same problem. Turns out that I didn’t have the lid open fully abd the vinyl was rubbing slightly on the lid!
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
You are amazing thank you so much I was literally freaking out over this. Super helpful my guy thanks again
tarafından
Yorum Ekle
I'm not sure how old yours is, but I'm guessing since it has a disc player it's pretty new. I have a different brand player, produced in the last ten years, that slows down often. To adjust the timing on it there is tiny mechanical part on the inside that you can insert a jewelers flat head into and lightly turn to adjust the timing. I usually pull up a song on YouTube and use it to compare to the record. However if you adjust it while a records on you risk scratching.
Mine slowed down so often I drilled holes in the bottom to access it without tearing the player apart everytime just to adjust it. After all I can't listen to The Bee Gees slowed down
-Liz
Here's an image of the part, I have three, one for each speed.
Puan 1
1 Yorum:
no only a motor underneath. no place for adjustment. sad
tarafından
Yorum Ekle
Your belt underneath the platter is either stretched or slipping.
Puan 0
Yorum Ekle
Yanıtını ekle
Dan Strickland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 11,823
