Ana içeriğe geç
Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
71 Soru Tümünü görüntüle
Camera and led not working huawei p9
Recently, i broke the screen and had the LCD digitizer replaced by a local guy. Upon replacement, the screen itself did not sit completely flush and there was a small glimmer of light that you can see through the side of the digitizer; no biggie all seemed to be fine.
however now the LED does not work (i open the flashlight app and nothing happens), Nor does the camera app work. When I open the camera app, the app dies and doesn't open. When i try an app that would USE the camera, there is an error message saying "the camera is in use by another application".
So-- I'm unsure if the camera or LED worked prior to replacing the screen. I honestly didn't think to check. The screen was damaged pretty badly.
Ideas.?
I have called Huawei US and as this model (the p9) is an "International model" they (Huawei) will not help. Which is weird. but alas true.
I know that this phone is not in the US yet, but it seems that if I can't fix it, it is a big risk to buy another knowing that if I break the screen, im screwed.. any ideas..?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
I have the same problem but after a battery replacement. The flashlight works however, but I had to activate it from the lock screen the first time (it was blacked out in the notification/quick settings)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Chuck Colby sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,470
