Ana içeriğe geç
AirPort Extreme baz istasyonu ile birlikte piyasaya sürülen bu sabit disk donanımlı model, bir Time Capsule NAS cihazında 802.11ac hızı sunar.
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
Bu iyi bir soru mu?
Puan 3
10 Yorum
@shoeib hey bro, did you find a solution?
tarafından Paylaş
@ironjer - I'm sure a new fan fixed the cooling issue
tarafından Paylaş
@jesus no man. I eventually came to the conclusion that the logic board is fried.
tarafından Paylaş
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
tarafından Paylaş
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
tarafından Paylaş
5 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
tarafından Paylaş
@danj would TG Pro read this?
tarafından Paylaş
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
tarafından Paylaş
Yorum Ekle
See if any of the following articles can help:
Puan 1
Yorum Ekle
Yanıtını ekle
shoeib sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 3,542
