Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
Ps4 model CUH-1115A Question
So I have two ps4's...both are broken in a way, the CUH-1001A has a dead power supply unit, it won't even turn on...
I also have a ps4 model CUH-1115A..it turns on and I can play Dvds in it, but the blu ray reader is burnt out...will my disk drive from my CUH-1001A work on my 1115A model?
I know the power supply from the 1115A model won't fit in the 1001A model,so that's dead....
Any answers would be appreciated.!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
According to this, yes.
http://www.newegg.com/Product/Product.as...
Also if you need a power supply for the other one:
https://www.amazon.com/Original-ADP-240A...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
If I happened to put the wrong disk drive in would it harm my ps4?
tarafından
Due to the redesign, I don't think it would fit right if it were the wrong one.
tarafından
Yorum Ekle
You MIGHT be able to swap disc drives. There are several things to keep in mind:
1) Be sure that you keep the drive board from the disc drive with the motherboard that it came with. They are married and cannot be swapped.
2) You need to make sure that the wide ribbon cable that goes inside the disc drive will fit onto the drive board from the swapped drive. There are two different styles and they aren't the same size.
As long as you do those two things you'll be fine.
PS. Yes, the power supplies are not interchangeable.
Hope this helps.
Puan 2
Yorum Ekle
Yanıtını ekle
Bryan Lee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 4,594
