I cannot get my charge cord to make a good connection phone will not c
I cannot get the charge cord to make a good enoughconnection to charge my phone.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your charging port is likely worn out. You should try to replace it. It could have a separate board for the port, or it could be soldered directly to the motherboard. If it is on the motherboard, you should see if you can find a replacement motherboard. Soldering a new port directly onto the motherboard is difficult. If it is using a cable to connect to the motherboard, just replace the board the port is attached to. Hope this helps.
Bu yanıt yardımcı oldu mu?
Chances are the cable plug is at fault. I had the same problem with a tablet and replacing the cord did it. If the cord has a USB plug at the other end that's even better. If the cord goes directly into the "wall" power supply case the job is trickier and you would rater need a skilled technician to do it.
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 77
