usb ports do not work at all
the two usb ports on the right side do not work at all
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Get into your device manager and scroll through all of your USB Controllers. The ones with a yellow triangle indicating issues means usually the driver(s) needs to be updated.
Or it refers to a hardware error.
I forgot to state: you could disable the power management on the USB hub. Windows tries to disable devices when not in use to save on power. As above, tree branch out the USB Controllers, root hub and right click properties. Tab Power Management and uncheck where it says allow PC to turn off device.
Save and restart your PC.
Also, they are probably USB 3.0.
Shaun
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 237
