Ana içeriğe geç
Honda'nın kompakt otomobilinin yedinci neslini nasıl onaracağınızı öğrenin.
replace map sensor do it yourself
where is map sensor? and how to get to the sensor
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Dicksen Mah , The MAP sensor on the Honda 1.7 engine is stuck in the intake manifold right beside the throttle body(driver side) held by 1 bolt. Remove plastic filter air ducting from above throttle body. Remove the map sensor by unplugging wire connector, remove the single bolt, then grab the sensor and with a slight twisting motion pull sensor out. Be sure the old rubber O-ring is still attached to the old MAP sensor. Install the new sensor in reverse order. See the 1st link below which will help identify the MAP sensor you want to replace and the 2nd link actually points out the installed MAP sensor at the 3:23 minute mark and shows how o remove the plastic air intake filter/housing. Good luck.
http://www.autozone.com/engine-managemen...
https://www.youtube.com/watch?v=_jNqw9HE...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The sensor is right after the air box
Puan 0
Yorum Ekle
Yanıtını ekle
Dicksen Mah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 62
Her zaman: 14,048
