Ana içeriğe geç
Third generation Surface Pro tablet, released June 20, 2014.
123 Soru Tümünü görüntüle
Surface Pro 3 wont cut on after Screen replacement
Ive done a few surface pro 3 screens with no issue. This wont cut on at all after replacing the screen. Ive tried the original screen, a new power button, and a new charger.
The charger LED is white, which according to the Microsoft website indicates a charge.
Any help would be greatly appreciated.
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum:
Did you fix this issue? I'm having the same problem
tarafından
anyone sorted this?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Both the LCD and battery connectors have a tiny PC board that sits between the MB and the connector. When you disconnect the cable, there is nothing holding them in place and they often come loose and get lost. If the LCD one is missing, nothing shows on the screen. But it will turn on. You can check this by connecting a monitor via the HDMI cable. If the battery one is missing, it won’t charge and won’t turn on unless the power cable is plugged in.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I replaced the screen in one unit as well (completely destroying the old one in the progress like everyone does) and installed a new one. When I got the replacement screen it was delivered without the connecting cable to the motherboard (next to the connector for the digitizer and the battery) so I had to use the former one.
When I tried to power it up it would not show any signs of life so I connected an external monitor just to be sure and it worked like a charm. I found that the connection from the lcd to the motherboard was kind of wacky and wobbly so I used a small strip of duct tape under the metal strip which should do the job and it held perfectly.
By the way my unit would run easily without a battery connected!
Puan 0
Yorum Ekle
Yanıtını ekle
hustlemanentertainment sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 629
