Ana içeriğe geç
Acer Chromebook C710-2847, Acer'ın Google'ın Chrome OS işletim sistemini çalıştıran düşük fiyatlı netbook serisinin bir parçasıdır. Cihazlar, parçalarına ayırmak için yalnızca bir tornavida gerektiren basit bir yapıya sahiptir.
Is there a Screen switch?
Recently started having problems with the screen turning on/off intermittently. Opening the screen sometimes it goes blank, fades or screen is all grey. Noticed that if I grab the right corner near the hinge and squeeze upper and lower halves together it comes on. Also noticed the screw at that corner holding the halves together is stripped. Is there a switch in there that activates the screen when opened. I cannot remove the stripped screw. It is stripped in place and will not come out. Any help would be appreciated. Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I believe you would have to replace the LCD, I've had this issue in the past and I believe that's what I did. There should not be an "LCD Switch" and as for the stripped screw, I would try using a flat heat. I use two methods of removal of stripped screws. I either solder something into the screw and then remove it or I Dremel a pattern and unscrew it with a flat head.
I'm not sure if this helps but good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dennis Damico sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 388
