Ana içeriğe geç
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
Connecting better speaker by cable to Dot
Can anyone recommend a external speaker to be connected to dot, BY CABLE. I do not want to run my wireless JBL speaker by Bluetooth and leave it plugged in on charge all the time
reason, Dot was a gift and I want better speaker quality without spending full value of larger Echo.
Connector cables I can purchase, but want recommendation of speaker.
And her is final question, If I get set up by cable, (external speaker) will it convert to only the nice stereo speaker take over, or will have I have both on at same time.
Ron Harke, feel free to email with thoughts at rhaci@charter.net.
Thanks for your time to work out this converting , because of a gift. I would have bought the better one. d
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Any speakers will work. There aren't speakers that are better for the dot than they are for other devices. Try a NAD 7225PE amp with a pair of Mirage 360 speakers. That's my setup, and I think it sounds great. The dot has 3.5 mm jack audio out, which can plugged directly into most powered speakers, but if you have an amp+speakers, you likely need a 3.5mm to RCA cable, which is about $5. The full size echo doesn't have a 3.5mm out, so your stuck with the built in speakers. I don't understand the part about "If I get it set up by cable, (external speaker) will it convert to only the nice stereo speaker take over, or will have I have both on at same time?" Are you asking if the speaker built into the dot will play while you have external speakers plugged in? If that is the case, than no, the built in speaker will not play, but the stereo ones will. Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ron Harke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 4,652
