Ana içeriğe geç
A pico projector designed to work with Apple products.
5 Soru Tümünü görüntüle
no projection or light
Continuation has the purchase of a cinemin swivel, I have a problem:
When I switch on the pico connected to an ipod, an image is projected with the cinemin logo; but two seconds after, nothing more no projection or light which goes out of the device.
By looking the lens I has fault sees a small light at the bottom of the device
Bu iyi bir soru mu?
Puan 1
2 Yorum
Any fix for this problem with the swivel?
tarafından
nyl777, it would work so much better for you if you ask your own question and give as much detail as possible if you are expecting any help with your device. Your two questions on ifixit actually show up as answer to older questions. Click on the link on the right hand side of this page, where it says" Ask a question" Give it a try, it is not difficult and you may get some help for your problem. Good Luck.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds Like a the bulb has burnt out. Hopefully its not to expensive.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
How to be safe that It is the bulb, because the device does not have was used
tarafından
He reacts in the same way when no device is above connected
tarafından
Yorum Ekle
Are you using it with an iPhone, iPod, or iPad? Because if you are, you need to use the little adapter. It should plug into the charger port of the iProduct, not the headphone port, and then the 3.5mm plugs right into that. I had this same problem, until I noticed the adapter lol
Puan 0
Yorum Ekle
It may be the cord or the adapter. Sometimes, I have to plug my DVD player white into the yellow, and the yellow into the white in order to get the picture. It's like a crossed wire or something.
Puan 0
Yorum Ekle
Does anybody know where I can find the blue cord that connects the cinemon swivel 8410 projector component with the battery component?
Puan 0
Yorum Ekle
Yanıtını ekle
specie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 2,909
