Ana içeriğe geç
The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
Why will the cyllow and Cyan ink cartridges not work?
Hello: I printed my holiday cards and it used a lot of blue and yellow ink. I changed the cartridges and now only the black and magenta are working even though the blue and yellow are full.
Do the print heads need cleaning? How do I do that?
Thanks, Arlene Zapata
visual7645@sbcglobal.net
312.402.5472
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
This sounds like it needs a print head cleaning. It's simple, just touch the "Setup" button (looks like a wrench and a cog) and then touch "Tools", then "Clean Printhead". It may need more than one cleaning done, which does use up ink, but is necessary sometimes to clear the lines. I've had this happen many many times. Are you using HP replacement inks or generic refills? I had a printer completely die on my from using generic inks, it can really damage some printheads. If you need more of a step-by-step solution, you can search your browser for your printer name (HP Officejet Pro 8600) and I am sure something from HP's site will turn up in the results for your to reference. Good Luck!
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
the HP officejet 8600 will NOT clean heads, or align them or anything, not even print in grayscale if there's one empty cartridge. :(
tarafından
Yorum Ekle
Yanıtını ekle
visual7645 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 161
