Broken phone - GPS/Network dead
Long story short, I was having a problem with my camera, so I whacked the phone on the palm of my hand a couple times (yeah, that might help! [lol]) and after that I lost the GPS and network.
I am on T-Mobile running Android 7.1.1.
I cleared the cache, tried different combo's of network settings (2G, 3G, 4G LTE), rebooted in safe mode, cleared the network settings, etc. Nothing has worked. I get Wi-fi but no T-Mobile network bars (the triangle is blank) or GPS.
I've opened the back of the phone previously to replace the glass (as a glass+frame module) and battery and everything worked fine after reassembly.
Someone on another forum suggested look at the antenna connections and pointed to the photo here on iFixit.
When I popped the back open and looked closely at the connectors on the upper right side of the phone (looking at the phone with the back off), I could see that one of the connectors in the duo pairing was bent. Also the single connector below the duo connectors on the right side also looked a bit bent.
I straightened these connectors and they looked good to me afterwards.
However, I still get no GPS or network. Wifi works fine
Is there a Nexus 5x service manual available? Could anyone suggest (would need clear instructions) anything else to test? Maybe I broke a solder connection? Everything looked tight to me when looking through a magnifying glass but I don't really know everything I am looking at inside the phone.
I'd hate to have to buy a new expensive mainboard to save this phone!
P.S. Here is a link to some photos of the damaged clips before I repaired them:
Bu iyi bir soru mu?
What kind of problems were you having with your camera that made you whack it??! All jokes aside, you might have broken something especially if you used a lot of force when trying to fix your camera problems. I can't really suggest anything since I haven't had these type of problems myself so that's why I commented rather than answered.
Enrique tarafından
