Ana içeriğe geç
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Soru Tümünü görüntüle
The s pen only works in a few parts of the display
I replaced my display with a new note 5 display, that i got from fixit.
all works fine with the finger. Only the s-pen works in a few areas of the display.
is the s-pen broken or is the display itself not ok?
how can this be explained?
also the return and the window button work but don´t glow anymore.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
For the S-pen issue. That sounds like an LCD failure. The S-pen wouldn't work at all on the screen if it were the S-pen.
As for the soft keys at the bottom, make sure that the bottom PCB is connected properly and that you don't have power saving mode turned on. Also try a factory reset and if that doesn't work try flashing it. If that still doesn't work then it might be a bad PCB at the bottom there. You possibly damaged the buttons when removing the LCD. It happens all the time for me at work.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hey thank you! I will see what I can do when I get to it!
tarafından
No problem bud.
tarafından
Yorum Ekle
Yanıtını ekle
Michael Beutler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,063
