Ana içeriğe geç
15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
20 Soru Tümünü görüntüle
Trying to reinstall OS
Hello everybody (again).
I previously posted about a fault with my g4 not turning on, which has now been sorted. But now I'm faced with another problem!
I bought it from eBay, faulty and the fault has been sorted. But now I don't have the login password and I'm having trouble reinstalling the OS. I have all of the original discs but when I insert the install disc and hold C nothing happens, it just loads up to the login screen. I'm using a Windows keyboard but that's never been a problem in the past. My guess is a faulty CD drive but before replacing that I was wondering if anybody has any tips for me? Maybe a way of creating a usb drive that I can install the OS from? Or another idea is to install the OS on an external drive and clone it to the internal drive, but I'd need directions on how to do this. I have plenty of iMacs and Macbooks lying around if that helps?!
I'd love for an answer to my problem as its in brand new condition and has every piece of original packaging, etc..
Thanks in advance
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
It's a wired keyboard which is responsive in the login screen so I don't think that's the problem. I'm fairly sure I tried holding alt, but I'll give it another go tomorrow. Even if no CD is detected will holding alt load anything up? Or will it just boot as normal? Thanks for your help
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Is it a wireless keyboard? My iMac will not go to the boot selection screen with a wireless keyboard. I have to plug in a wired one. Try to press and hold alt to get to the boot menu and then select the cd.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi
You can install snow leopard on a usb
Maybe try that
Thanks
Puan 1
1 Yorum:
Snow Leopard was an Intel only release, so that definitely will not work.
tarafından
Yorum Ekle
From my experience working on these, it’s commonly the DVD/CD drive that goes bad, I’ve had to replace several of them.
  1. You could try is booting from a Firewire 400 external hard drive with OSX installed on it by holding down the alt/option key when starting up.
  2. Or you could optionally connect it to another Mac that also has a Firewire 400 port and put that Mac in “Target Disk Mode” by holding down the T key at boot.
I know this post is old, but this is for anyone else that might have this issue in the future as it might be of some use to them.
Puan 0
1 Yorum:
yep, these era of machines will ONLY boot from firewire devices so using a USB drive is not possible. This behavior only changed recently as I recall because my 2008 late model MB Pro still would only boot from firewire devices
tarafından
Yorum Ekle
Yanıtını ekle
Andy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 898
