Ana içeriğe geç
First released in September 2013, the T440S is a lightweight, durable 14" business notebook that shipped with 4th generation Intel processors.
16 Soru Tümünü görüntüle
Why is my laptop not coming up
it switched off by itself and never came up after that..
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Are there any lights or sounds when you turn the computer on? If it is plugged into the ac adapter, is there a light showing that it is charging?
tarafından
Yes their is light and sound when I turn on the computer
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Look at the power cord and make sure that the laptop has power. Sometimes the device dies and either the lightning panel was damage or the battery was damaged. Look upon that and if it turns on and does not show anything on the screen try plugging to the HDMI to another device in case it is just the screen.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Check if the light on charger stays on when its plugged into the system.If yes,disconnect the charger,remove the battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger,turn on the system and see if there is any change. For better and effective solution please watch troubleshooting instructions in Lenovo ThinkPad T440 Manual.
Puan 0
Yorum Ekle
If it appears like a dud, undo bottom cover, remove cmos and internal battery connect back, it should be working again.
Puan 0
Yorum Ekle
Yanıtını ekle
mustapham.sodiq sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 395
