Red dot with no red ring lights
When I turn on my XBox 360 (newer version) the green light in the middle of the circle comes on for about 5 seconds then turns red. There are NO red ring lights around the edge of the silver button, ONLY the red dot in the middle. I took the hard drive out and put it back in, that did nothing. The power supply has a green light. I also tried two other HDMI cables and still nothing. Does anyone know what the red dot without any red ring lights means?
Bu iyi bir soru mu?
9 Yorum
Having this exact same issue, green light on the power supply and everything. Taking out and trying to remove dust from the HDD didn't work, either.
George Fawn tarafından
Apparently when it is red you can hold down the sync button and press the DVD drive eject 4 times. Each time you will get a number (with four lights = '0', one light = '1', two lights = '2', and three lights = '3' ), and that number is an error code you can use to figure out what more specifically is going wrong with the Xbox.
Mine was 0110, which apparently means it's probably an issue with RAM needing to be reflowed.
My code is 0-1-0-1 does anybody know what's wrong with my Xbox 360 slim 250gb black?
Brandon Perry-tenn tarafından
@omninano Do you happen to remember where you found these codes? I have code 3302 and can't find any information.
rlee91894 tarafından
Hey guys i need some help with
my rgh xbox 360 s recently start turning red when i try playing some specific game off my hard drive but when i put the same hard drive in a different game it works perfect
bell.stacyann tarafından
4 tane daha yorum göster
