Replace door latch assembly
How do I disassemble the door to replace the latch and spring assembly?
Microwave #721.85033010
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I would strongly suggest to order the complete door. The door is easy to replace, just lift up.
There is a risk of microwaves leaking after the door is dissasymbled A survey test is required after repairing a door. If you don't own a survey meter and aren't qualified to use one, then order a door.
Bu yanıt yardımcı oldu mu?
jason haddad , The link below will show the break down of parts on the door assy. I my self do not condone inexperienced persons working on Microwaves as they are one of the most dangerous appliances to work on and take considerable knowledge in most repairs to prevent harm to persons and device. Good luck.
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 3,293
1 Yorum
I had found that previously but it doesn't really show how to disassemble the door.
jason haddad tarafından
