Ana içeriğe geç
LG K7, LG tarafından Şubat 2016'da piyasaya sürülen ve Android 5.1 işletim sistemiyle çalışan bir akıllı telefondur.
Wifi calling connection not working.
My home is in a weak cell network location -- 1 or 2 bars at best. Although I have an excellent wifi network connection from my LG K7 to my home Comcast router, I'm unable to maintain a constant wifi calling connection at home. Other outside router connections to wifi calling seem to work well.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum:
I can get calls in but can't call out.just started last week off and on .now can't call out at all.my internet provider is frontier. I have basically the same problem as Edward Driscoll i have a strong wifi signal
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
make sure you have data all the way off or it could bottleneck the speed of your wifi
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had the same problem and I just found the solution for me. I had to log onto my router (Lynksys connected to my Comcast modem) and disable IPv6. IPv6 uses longer IP addresses; LG K7 only supports the shorter addresses used in IPv4. So when I had both IPv6 and IPv4 enabled, my phone sometimes got sent the longer address, which caused it to not connect. Turning off IPv6 makes it work all the time now for me.
Hope this helps.
Puan 0
Yorum Ekle
Yanıtını ekle
Edward Driscoll sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,557
