Not sure which models will work or not........someone else may be able to answer your question better then I can I'm sure.
if you need to know which display you currently have in both machines, the model number or other information, this is a command line (terminal window) that will show your LCD model number and your color profile. (assuming you can hook up the laptop with the shattered screen to an external monitor).
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
(this makes it easier to find information about each screen and the specs for each screen which may give you a better idea if your swap will work).
My best guess would be no, since the machines are quite different in age the data cable that carries information to the LCD screen is probably not the same.
If your swap will not work you will know the model # screen you need making it easier to find the correct replacement and parting out or selling the older machine, assuming you no longer need it would more then likely pay for a new screen for the macbook pro.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
3
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum
Hello John, Best person to answer this is Ben. He should be along soon. Good luck. Ralph
rj713 tarafından
