Ana içeriğe geç
Model A1502 / 2,4, 2,6 veya 2,8 GHz çift çekirdekli Intel işlemci / Ekim 2013'te piyasaya sürüldü
HDMI port stopped working
Hi
i have my HDMI stopped working when i connecting it to my LG smart TV ,, when i connect the TV recognize the signals from my MacBook but it say no single .. at the same time the MacBook doest see the TV any more ....
it is a software issue or hardware issue and how to check and fix ?
thanks
Bu iyi bir soru mu?
Puan 3
6 Yorum
well after trying everything on the net i realised the the chord was plugged in upside down because it fits both way it simple to think its plugged in correctly turn the adapter chord around it worked fine
tarafından
you can't plug an HMDI cable in upside down it only fits in one direction and there's an icon on the plug. Suggesting that the No Signal issue is cos the user forced the cable in upside down, and should put it in the one way it fits for it to work, is a non-fix that doesn't address the issue at all
tarafından
I had the same issue happen all of the sudden . The solution that I used was to go the systems- displays- check (mirroring option in the menu bar when available) this made the image display on the TV
tarafından
I know what Chris Smith is trying to say. On my HDMI cables, there are little arrows showing which way the signal flows. It comes out of the computer and flows into the TV set. I turned the cable around -- unplugged the computer end and plugged it into the TV and vice versa -- and suddenly my system worked again.
tarafından
hello,
I used to connect Mac pro capsule to external display via HDMI cable but now when i turn it ON , it doesnt give display. i cant connect it via thunderbolt because my LCD doesnt have it. im wondering why all of a suddent Mac Pro HDMI stopped working. please help!
tarafından
1 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try plugging into another TV and using a different cable. If still not working, guide to replace the HDMI port can be found here MacBook Pro 13" Retina Ekran 2013 Sonu I/O Kartı Değişimi
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
I tried
1) Try a different HDMI cable
2) Try a different HDMI port on the TV
3) Use Thunderbolt to connect to the TV
No luck
But still when I connect the MacBook Pro the laptop see the tv but the TV show No Signale.
It was working fine for so long with the same tv with no issue.
Also I have my Amazon FireTv connected via hdmi with no issue.
tarafından
Sorry I didn't try ThnderBolt.
tarafından
Try plugging it into a different TV (not port) using another cable. If it is still not working, change the I/O board as mentioned above. Also, check Thunderbolt to isolate the issue.
tarafından
flip the adpter around it will work
tarafından
Yorum Ekle
Rebooting my laptop fixed the connection issue. Rebooting seems to help with many issues.
Puan 2
2 Yorum:
thanks man, I rebooted my laptop when the HDMI port and everything is connected and it works fine now.
tarafından
Thanks man rebooting system fixed the problem
tarafından
Yorum Ekle
https://www.amazon.com/AmazonBasics-Mini...
Puan 1
Yorum Ekle
flip the adpater plug around it will work its a simple mistake
Puan 1
3 Yorum:
Are you sure you are answering the right question? HDMI ports only allow the cable to be plugged in one direction. If you are able to flip the cable around and plug it in, there is something wrong there.
tarafından
Indeed, I've got the same NO SIGNAL issue, and both the MBP and the TV end of the HDMI cables can only be inserted one way. Flip what round? The answer doesn't make sense sorry. It was working perfectly then suddenly lost signal after unplugging and replugging the cable when I moved my montior.
tarafından
For the thunderbolt computers there's an adapter for the USB-C that you can flip around
tarafından
Yorum Ekle
My MacBook Pro 13” 2015 will not detect HDMI plugged directly into the HDMI port, but will detect the same cable if I use it with the thunderbolt adapter???
Puan 0
Yorum Ekle
I solved this issue with my 2012 i7 mini by using a mini DV to HDMI adapter after the existing HDMI port stopped working. Now I have to figure out WHY it stopped working. But in the mean time.. the adapter to HDMI works perfectly.
Puan 0
Yorum Ekle
Yanıtını ekle
zagil69 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 105,144
