Ana içeriğe geç
A Turbosteam iron by Morphy Richards.
15 Soru Tümünü görüntüle
power problem with my iron
Suddenly my iron has stopped working. The light doesn't come on and also it does not heat up. Please help me.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
dumevisenyo , Since it appears not to be coming on at all, try a different known working outlet, if not that the plug/power cord may be faulty or could be burnt off at connection in the iron. See the link below, tear down guide for your Iron so you can disassemble and test/check all wires/connections/switches/contacts/etc., visually and DVOM, to see if you can determine what has failed. Good luck.
Morphy Richards Iron Teardown
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
dumevisenyo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 5,885
