Screen lifting on Z3 compact
Hi my screen is lifting, I've tried precut tape normal double sided tape, I've taped both the phone and the screen. Nothing I've tried actually makes the screen stay. What else can I try.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Tesa 61395 or Original screen adhesive. Tesa probably better.
Bu yanıt yardımcı oldu mu?
Check the thickness of the screen with Digital callipers and compare it to an Original which is around 1.9 mm , as much as 2.1 mm will cause this problem. Also you need to use Original hot melt adhesive instead of that generic grey pre cut suff.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 361
