Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
3 Yorum:
Use the volume and power buttons to reset the device. Try hold volume down button and then press and hold the power button, if that doesn't work after about 30 seconds try holding the volume up button and hold the power button for 30 seconds. One combination is a hard reset and the other gets into BIOS.
It is NOT worth buying a Tablet whose manufacturer is not responsible for the system that carries the device. IF for whatever you need technical assistance, make sure you buy from a manufacturer that really supports you. The experience of the support has been bad, and a tablet without the system can not work. All manufacturers have on their pages the systems of their devices to reload if it fails or malfunctions. Irulu only has the last month or year. If you are going to use the tablet for less than a year, maybe it lasts for you, but if the purchase is going to be longer, my advice is that you buy from another manufacturer. It is not worth buying a product that has no support and you know you can not use it more than a limited time. Irulu is the worst place to buy
DrGlowire tarafından
I did that still doing the same thing. i even left it on to drain the battery then recharged it still same
apache_99_2000 tarafından
mikra tarafından
