Ana içeriğe geç
iPhone'un ilk modeli. A1203 modeli, 4GB, 8GB, 16GB kapasiteye ve alüminyum arkaya sahiptir. Tamir, kayda değer miktarda kanırtıp açmaya ihtiyaç duyar ve lehimleme gerektirebilir.
224 Soru Tümünü görüntüle
How do I unlock?
I have an iPhone 2G 8GB currently on firmware 3.1.3 and on baseband 04.05.04_G
First of all I live in Canada, so I don't know if that makes a difference or not.
My carrier is Bell.
My phone is jailbroken, tried several different ones; redsn0w, blackra1n, Pwnage... I've tried to unlock several different times mostly using Bootneuter 2.1
I've tried both bootloaders 3.9 and 4.6
The phone will work with Rogers. My SIM will work on 3G's.
What is it that's not working here? Is it my Sim is too new for the 2G (which shouldn't be the case since the other Roger's sims work) or does Bell not support the 2G? I've spent hours and hours trying every possible combination. Tried to use Fuzzyband 4.1 to downgrade the baseband, but couldn't find an early enough version that would work.
Please.. if you have any suggestions, let me know, because I'm out of ideas and think I may either have to switch carriers, or be stuck with a glorified iPod Touch.
Bu iyi bir soru mu?
Puan 2
2 Yorum
I like the idea of getting on my phone. keep getting it right now and again I will be in touch with you. How do I boot up my phone contacts. All of my Google Apps
tarafından
I have a apple iphone 1 and I need to know how to unlock my apple iphone 1. I have email address in my old apple iphone 1, can someone have a video of the unlock my apple iphone 1.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have discovered that my problem was not with not being able to unlock it, but that the Bell network only supports 3G GSM networks or higher. They didn't create one for the 2G, therefore my iphone 2G will never be able to work with my carrier. Only solution is to beef it up as much as I can, sell it to someone who goes with a carrier that support 2G, and get myself a 3G (or maybe an iphone 4 will fall into my lap).
Anyhow, thank you for all your help and suggestions.
And if anyone knows how to trick a 2G phone into working on a 3G network, I'm all ears. :)
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
How u get a passcode off ur iPhone
tarafından
Yorum Ekle
En Yararlı Yanıt
I was able to jailbreak and unlock a couple SIM-less iPhone 2Gs with the assistance of this link. I know you stated you've tried Redsn0w, but perhaps the specific procedure and files mentioned in the link are different than what you've attempted?
http://www.ilikemyiphone.com/2010/02/10/...
Puan 4
3 Yorum:
Was pretty sure I had tried redsn0w 9.3 and 9.4 already, but I used your link and tried again. Still says I have an invalid SIM, and under Network and Carrier it says "not available". But I know my SIM is valid and activated with Bell, just doesn't want to work on this phone. Any other suggestions?
tarafından
Hmmmm...like I mentioned I jailbroke/unlocked it without SIMs in the iPhones...maybe try the process without the SIM and then put it back in? I don't know if that would make a difference but it's an idea.
tarafından
Tried both ways. With and without SIM. With Bell SIM, and with Roger's SIM.
tarafından
Yorum Ekle
See if you tried it this way. http://www.technonix.com/2009/11/unlock-... and here is the forum for people that have a hard time with their carrier etc. may be this is something that pertains to your situation http://modmyi.com/forums/t-mobile/325421...
and http://www.sinfuliphone.com/showthread.p...
Puan 3
3 Yorum:
Been there, it's for 3G or 3Gs, I have a 2G. And my baseband is 04-05-04_G, not 05-11-07.
tarafından
I had just read that it said " For iPhone 2G
It works for iPhone 2G too. Follow steps 1-3 above. At step 4, there won’t be any “sn0w” option. Just tap Cydia and/or Rock at this step. Rest of steps remains same." that is why I suggested the link. Sorry.
tarafından
Yorum Ekle
Yanıtını ekle
Brownbailey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 63
Her zaman: 28,071
