Ana içeriğe geç
An in-car GPS manufactured in 2012 by Garmin.
9 Soru Tümünü görüntüle
Charging port no longer charges
I have replaced the battery on my 3590.
The new battery (tried two different ones) was fully charged before connecting it.
However, whether I plug it into:
1) The wall charger
2) Laptop USB
3) Cradle charger
The battery will not charge.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Colin Marson , I take it worked on the new battery till it died and now refuses to charge. Did you check the port and blow any dust/debri out of port. Look in port and straighten any bent pins with tooth pick very carefully. Still no go, remove battery door and with a DVOM with charger plugged into device check plug at battery to see if charger is sending voltage to battery, if not probable loose/bad charge port,change the charge port. the link below is a tear down guide that can get you access to the charge port which is soldered to the mother board and is not a job for the newby because of the fine components and heat involved. 2nd link shows a charge port being resoldered.Good luck.
Garmin nüvi 3590 LMT Circuit Board Replacement
https://www.youtube.com/watch?v=5z5KLwKn...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The difficulty is that neither the USB port nor the cradle connection seem to be providing a charge ( the battery icon does not show that it is being charged)
Puan 0
Yorum Ekle
Yanıtını ekle
CAM sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,124
