Ana içeriğe geç
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
Solution to unresponsive volume buttons?
ZTE ZMax Z970. The volume buttons are randomly responsive, will work for an hour or two before I have to go back to adjusting my volume through settings. I'm not sure if this is a hardware issue or software. Possibly related: adjusting the headphones jack when something is plugged into the phone causes the Google app to open up and listen for commands; sometimes, it will suddenly increase the volume in increments and I have to manually change it back. Where would I take it to be repaired?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You should download the app called
Virtual volume button that should fix the problem
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Okay so I'm not exactly an expert but press the center of the volume buttons into the phone and that fixed mine actually a little bit to where they are more responsive. If that doesn't work then play with the buttons to find an angle they work at.
Puan 2
Yorum Ekle
Yanıtını ekle
Cassandra Pentaghast sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 7,472
